What tuning is required for a cam??
1. Adjust rev-limiter to range of cam. This would be set to take advantage of the peak power of the cam.
2. Adjust Idle speed. This will sometimes need to be changed depending on the cam.
3. Adjust for IAC counts
4. Tune to achieve desired A/F ratio
This is just a few things, but it is a time consuming process, but well worth it....
