stupid questions about the predator, a/f stuff
how do i tell if im running rich or lean with this?
Sorry this is the first time i've tried this and feel stupid looking at the information
One other thing im not sure if i was reading it right
but there is
long term
and short term
one of them at part throttle was -# while the other was between 20-30%, then at WOT the one that was negative went to 0 and the other went to 10.6
<small>[ November 13, 2002, 05:25 PM: Message edited by: jacs ]</small>
at idle
short term- keep jumping from 0 to -2.34 longterm 0\
short term- keep jumping from 0 to -1.56 longterm 0
at wot short term on both was 0 and longterm on both was at 25
there was no knock retart, spark was around 28-31, my o2 values seemed low, .79 or so was highest and it started droping as i got higher in the rpm range
the o2 values are very hard to look at while driving
Knock retard is not installed on the early versions. You can send the unit in and have the updates performed but it really isn't necessary at this point, especially if you are stock or only have bolt on's. If you can dyno the car then that will always be your best bet. It will clearly show a drop in power when the KR kicks in. And the A/F will become erratic as well. It's OK for the timing to be up at 40 degrees while cruising and 32 at WOT. The computer is compensating for various throttle positions and adjusting the timing accordingly. The engine can handle more timing at various TP's depending on air temps, fuel, etc. So don't worry too much about those numbers. Same goes for the 02's. Those numbers will vary quite a bit depending on the conditions. That's why that wideband 02 can be so beneficial on the dyno. Your LTFT's (long term fuel trim) measure A/F over an extended period of time. And the STFT's (short) measure over a shorter period. And I believe open loop (WOT) sends the STFT's into a dormant mode. And I'm not sure the LTFT's are awake either. But I could be wrong about that. Anyway, hope that helps to clear things up a bit. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
idle lterm was negative 3.xx and so was the second bank, my sterm was like negativ3e 1.xx something...
at part throttle and wot my sterms are always at 0, while my long term are always at 25 for bank 1 and 22 for bank 2. that is positive numbers
My timing was at about 30 for the most part
My knock at WOT never got above .83 at WOT, MY O2 bank 1 sensor 1 was at about 685 while the other bank was near 750... of course this is me just looking down while down ride open runs and seeing in about what area it stays, this was done on about a 40 minute drive with a few WOT runs, 10-20 or so....
The knock retard should be available for upgrade through the internet soon..
