Question about EFILive V5
Old Nov 17, 2002 | 12:00 AM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
Default Question about EFILive V5
We have two cars. Mine is a 2001 Firehawk A4, my husbands is 2001 WS6 M6.
On my A4 I can scan Delivered engine torque, but it will not record any values in my husbands M6. Is there a different PID that works in the M6s?
Old Nov 17, 2002 | 08:32 PM
Default Re: Question about EFILive V5
TTT
Old Nov 17, 2002 | 11:26 PM
EFILive's Avatar
Restricted User
Have you tried running the menu option:
OBDII->Check Pids (hot key Shift-F1)?
That will mark PIDs as either supported or unsupported for the connected vehicle.
The supported PIDs are saved in a file called xxxx.vin where xxxx is the first 11 characters of the VIN. The file is stored in the PID directory.
Each time EFILiveV5 is connected to a vehicle it checks the appropriate *.vin file to determine which PIDs are valid for that vehicle.
It may be worth running the check explicitly on the WS6. There are a number of Torque PIDs - one of them may be available on the WS6
Note: EFILiveV5 only implements the subset of PIDs (from the set of all GM PIDs) that are available on various LS1 equipped vehicles around the world.
Regards
Paul
Old Nov 18, 2002 | 08:35 PM
Thanks Paul, I will try that.
