What is the limit of scaling the MAF table on a 98?
Thanks
for trouble later. You need to incorporate a regulator in some fashion!
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
+25 means they are adding fuel to account for a lean condition. Was the pump/lines the only change?
I bet you have a vac leak somewhere around your PCV, EGR or MAF. 72psi FP shouldn't cause your LTRIMS to jump to +25
you can add an AFPR to your return line under the car (if you dont have a dedicated line off the rail) and dial down your FP with that.
Good luck,
Chris
i pinched my return line on my first install and it pegged my meter at over 100psi. needless to say the car ran like crap.
if the fp is up that high, tuning it is just not the right approach.
Its definitely +25 on the l-trims. Looks like I have a faulty O2 sensor but not sure that would cause that kind or problem. I'm swapping it this weekend regardless.
Any suggestions on how to use an external regulator. Would I have to change all my lines? I already have a line running from a 3rd Holley fuel pump that is dedicated strictly to nitrous use and arms with the nitrous switch. These two pumps are feeding motor only.
