Calibrated MAF Sensor for Larger Injectors?
Old Nov 16, 2002 | 06:27 PM
Just Chris's Avatar
Default Calibrated MAF Sensor for Larger Injectors?
I would really like to get one of these but I can't remember who has them or even if they are still available. Who has one and where can I get one calibrated for 38#'s or even 36#'s? Also if I do decide to go this route will this affect my reported load (as this will lower the injector pulse width) and increase my timming at WOT? Or am I on the right track in thining this?
Old Nov 17, 2002 | 02:13 PM
MIGHTYMOUSE's Avatar
Default Re: Calibrated MAF Sensor for Larger Injectors?
you are thinking mustang my man.. though you can compensate for a slight injector upgrade with this thing we got called a maf translator, or you can go get custom tuning, do it yourself with ls1 edit or even try your luck with hypertech..
Old Nov 17, 2002 | 06:40 PM
JAS's Avatar
JAS
David, you are incorrect. You can correct an LS1/LS6 MAF for at least 42.5lb injectors. (Haven't tried 50's because I didn't have them at the time.) It's fact it was done over a year+ ago. I ran 38lb injectors this way for a year myself. There are/were a handful of cars who ran with injector matched MAFs. Mostly 30lb versions.
With LS1Edit now, it pretty much a mute point.
