Better knock sensors?
Thanks
If you're doing an intake swap, yes this would be the perfect time to replace them, but if you're not getting false knock, you might not want to. If you can identify the knock sensor while you have the intake off (again, the new sensors have the female end, and the old ones have the male) this might help you make your decision. You may already have both the new knock sensors and no false knock, in which case it would be silly to replace a part that is working properly. If you have extra money and the old sensors, you might replace them with the updated design simply to circumvent any future problems. And also you will need the correct wire to go with them (obviously, as the connection-type has changed). Part number for the wire should be 15372170.
Hope this can serve as some help.
