COME ON GUYS, NEED YOUR HELP ASAP.
Rule of thumb is 1 point of timing reduction per 50 shot of the good stuff.
The timing reduction should be done for all g/cyl cells in excess of .56 g/cyl and for ~3000 rpm and up (or whatever you launch at). This should do your timing just fine.
Ensure that you keep the timing dip at ~4800 rpm. This is peak torque and it is important that you maintain this reduction in timing. Especially if you are on the juice.
Good Luck,
Kevin
