02-04 Maf tables
Old Feb 7, 2006 | 04:31 PM
MSGHUFF's Avatar
Default 02-04 Maf tables
Are the maf tables for 02-04 LS1/LS6/trucks the same? I ordered a MAF for an 02-04 ZO6 and cannot Identify it with the part number stamped on the maf the dealer tells me it will work but... they also sent me 2 ford mafs first.....
Old Feb 7, 2006 | 05:16 PM
jimmyblue's Avatar
Moderator
Here's what I have collected for part numbers:
25318411 New truck MAF (& LS6?) and '01 Z06
This P/N is used on most every V8 from '99-'05
supersedes 25168491
Z06 MAF 25341604 - '02 85mm
F-body LS1 MAF 25179711
Old Feb 7, 2006 | 06:02 PM
MSGHUFF's Avatar
the # on the white tag on the maf is 25328057 the stamped in the plastic delphi # is 25168491 any ideas on the tables?
Old Feb 7, 2006 | 06:50 PM
Steve01SS's Avatar
Yeah.. thats an 2001-2004 LS1 MAF or an 01 LS6 MAF with the screen. 02 + LS6 doesn't have the screen, but physically it's the same thing
Use the table info in here... http://www.ls1howto.com/index.php?article=25
You can run it with the screen or without... Just run the proper tables.
Old Feb 7, 2006 | 07:52 PM
jimmyblue's Avatar
Moderator
That MAF is an older truck MAF. I run it with the screen popped
out. This table has been good for me:
freq Hz 750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 1350 1400 1450 1500 1625 1750 1875 2000 2125 2250 2375 2500 2625 2750 2875 3000 3125 3250 3375 3500 3625 3750 3875 4000 4125 4250 4375 4500 4625 4750 4875 5000 5125 5250 5375 5500 5625 5750 5875 6000 6125 6250 6375 6500 6625 6750 6875 7000 7125 7250 7375 7500 7625 7750 7875 8000 8125 8250 8375 8500 8625 8750 8875 9000 9125 9250 9375 9500 9625 9750 9875 10000 10125 10250 10375 10500 10625 10750 10875 11000 11125 11250 11375 11500 11625 11750 11875 12000
flow gm/s 0.2 0.27 0.34 0.41 0.49 0.58 0.66 0.73 0.81 0.89 0.97 1.05 1.13 1.21 1.29 1.59 1.88 2.2 2.58 2.99 3.45 3.95 4.5 5.1 5.76 6.46 7.23 8.06 8.95 9.9 10.91 11.98 13.14 14.39 15.74 17.19 18.74 20.39 22.14 23.99 25.95 27.99 30.14 32.38 34.71 37.16 39.73 42.5 45.41 48.47 51.67 55.02 58.48 62.1 65.86 69.77 73.82 78.06 82.48 87.07 91.82 96.74 101.82 107.08 112.48 118.07 123.83 129.76 135.87 142.17 148.61 155.26 162.11 169.17 176.44 183.94 191.72 199.8 208.06 216.62 225.44 234.52 243.89 253.45 263.21 273.23 283.55 294.15 305.06 316.32 327.93 339.92 352.32 365.16 378.47 392.3 406.7 421.7 437.34 453.69
Old Feb 7, 2006 | 08:17 PM
MSGHUFF's Avatar
This is what it looks like. I cant rely on the number on the box, as you can see, this is the third different maf Ive recieved and each have been different. So back to my original question: are the maf tables for 02-04 the same for trucks/ls1/ls6? Also even though there are a million part numbers out there is the calibration the same for all of them? Thanks
Old Feb 7, 2006 | 09:10 PM
Steve01SS's Avatar
Saw your post over on the corvetteforum as well..
You run the calibration for the vehicle you have (or the combo you use in our cases), The sensors are really the same. If you run it with no screen, then use the 02+ Z06 calibration table.
Truck table will be different due to the intake system being slightly different among other things.
I'm running that same MAF with NO screen in my 99 FRC with the 02+ Z06 cal table. ZERO issues. Buddy of mine is doing the same thing as well..
steve
