Lean?????
Old Nov 21, 2002 | 08:28 PM
5.0eater's Avatar
Default Lean?????
I just removed the screen from my MAF on my 5.3. I was wondering if this will cause a major lean condition or if it will be minor or none. Would the lean condition be fixable using the new preditor programer or would I have to use ls1 edit? Also how much hp will the 460 trans support
Thank You for your Help
02 GMC SIERRA SWB REG 2wd 5.3, air raid, gibbson dual sport, de screened MAF. ET 15.5 87MPH
Old Nov 22, 2002 | 07:58 AM
NoGo's Avatar
Default Re: Lean?????
No, this will not cause a MAJOR lean condition. It will lean out your car slightly, but not much (maybe .5 a/f max), and defiantly not enough to damage it.
Old Nov 24, 2002 | 03:10 PM
30thta436's Avatar
If you weren't sure you should have asked before doing it.
It wont change anything enough to worry about it.
