Can anybody SAE correct my dyno??
http://www.upload2.com/fileviewer/ca...d825a18a53.jpg
There is my dyno, it says at the bottom STD: 1.02 Some say that SAE will be higher, and some say my SAE will be lower...My conditions are at the bottom, and i found online that they are worse than the SAE's so wouldn't that make my SAE numbers higher?? ANYBODY help??
There are a few different SAE atmospheric corection standards being used. The most common on chassis dynos is the SAE J1349 Revision June 90. It corrects to 77 deg F, 29.235 baro pressure "absolute" and 0% humidity. In your example you would have an SAE correction factor multipier of 1.001, gee, you have more then you thought.
