Skip shift and LS1 edit?
Old Nov 24, 2002 | 09:56 AM
sega rally's Avatar
Default Skip shift and LS1 edit?
Why is it that you can delete skip shift with LS1 edit, but you cant delete TCS or ASR with it?
Old Nov 25, 2002 | 12:22 AM
felton316's Avatar
Default Re: Skip shift and LS1 edit?
Just go to TCS retard vs RPM at set all values to zero. That should effectivly get rid of ASR/TCS. Even if the light is on, it will only pull zero's. I wouldn't recommend it, it can be helpfull in rainy days. Just turn the switch off.
Old Nov 26, 2002 | 12:17 AM
Predator's Avatar
Also, SLP sells a reverse module that defaults the TCS to off, at startup. If you want traction control on, you have to press the button.
