Stall Saver
Old Feb 8, 2006 | 09:50 AM
Patrick G's Avatar
LS1 Tech Administrator
Default Stall Saver
Anybody use it?
On my F-body, my IAC responds well to idle and anything with 0% TPS, but as I let the clutch out, my rpm can drop fast without giving it quite a bit of throttle. Is this something stall saver can help? If you're using it, what are your values?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 8, 2006 | 09:57 AM
Billiumss's Avatar
Good luck, I've asked many times and no one, including HPT, seems to either know or are willing to help out with this "Feature"...
Old Feb 8, 2006 | 10:01 AM
Zick's Avatar
http://hptuners.com/forum/showthread...ighlight=saver
Hopefully these will help.
Old Feb 8, 2006 | 11:05 AM
Patrick G's Avatar
Thanks for the links.
With a 900 rpm idle, where should I set stall saver to?
How do I handle the lower rpm?
Old Feb 8, 2006 | 12:09 PM
SmokingWS6's Avatar
In HPT go under Idle Airflow, throttle follower Decay(gear) and Delay(gear).
If you lower the decay values the slower your motor will return to idle and possibly prevent stalls, or near stalls. The Delay value controls the delay before it'll pull the motor back to idle speed once you let off the gas.
Old Feb 8, 2006 | 12:11 PM
jimmyblue's Avatar
Moderator
I recall bringing the "stall saver strategy" RPM up closer to
my idle RPM (my stock tune had all zeroes, I set it to 200RPM
below engine speed near target idle, closer-in at low RPM
(which should not be seen / matter) and 800RPM at higher.
350.00001 400.00001 450.00001 500.00001 600.00001 700.00002 800.00002 800.00002 800.00002 800.00002 800.00002 800.00002
Can't say with any authority, whether it solved anything
but I haven't stalled since doing it (not that it was a
problem before except on very cold mornings where I
had not done a good job with tuning airflow targets).
