P0135 Code.
Old Nov 25, 2002 | 02:57 PM
John02SS's Avatar
Default P0135 Code.
My car popped this code the other day. I know what the code is but what would cause this. I did a search and found several guys with the same problem, but no fixes. It just starting with the cooler weather also. Could that have any effect on the temp of the 02's? Hell, I'm in Florida! Everything is supposed to get hot enough here! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Also, at WOT the previously mentioned sensor give a .030 difference than Bank 2 Sensor 1. Could it just be Bank 1 Sensor 1 is going bad?
John
Old Nov 26, 2002 | 01:27 PM
John02SS's Avatar
Default Re: P0135 Code.
ttt
Old Nov 26, 2002 | 07:25 PM
Wt99C5's Avatar
I THINK your O2 heater is bad, or a blown fuse.
It's only tested at 50 degrees and below.
Old Nov 26, 2002 | 07:30 PM
felton316's Avatar
Switch the driver and passenger side O2s and see if the code changes to the other side with it. If it doesnt change when you switch the bad one, then its probably a wire or a connector somewhere.
