Fuel cells questions????
LS1 Edit cannot change your fueling maps specific to the individual fuel cells. Instead, we have to make block adjustments to the entire fueling schedule of the car via the injector flow rate table, MAF table, PE table, fuel-air multiplier table, Volumetric Efficiency tables, and IAC tables.
Each table is specific for certian situations of the car. For example
Injector Flow Rate Table: Changes fueling for all applications
MAF Table: Changes fueling for all close loop and WOT fueling (has side effects though)
PE Table: Changes fueling for WOT only.
Fuel Air Multiplier: Changes fueling for open loop upon start-up and "limp home" mode
Volumetric Efficiency Table: Changes fueling for all open loop fueling (has side effects though)
IAC Tables: Changes fueling for idle, park, neutral, "in gear" condition.
You need to determine where you want to adjust your fueling, and then make the changes to the necessary tables.
Good Luck,
Kevin
<small>[ November 21, 2002, 04:20 PM: Message edited by: ChrisV 02 - Z28 ]</small>
That, in turn, is used to calculate the grams/cylinder value that determines the timing value the car will use (see High Octane table), typically lowering the timing, as grams/cylinder and rpm increases.
My LTRIMs are around -4 for fuel cell 0 and gradually increase to around +5 for cells above 7. Would block scaling of MAF table work ?
Also, how are the on-gear and rolling part throttle fuel cells decided by PCM ?
The GM timing table is pretty accurate for lightly modified cars, and it is best to keep the trends that they have already set in to the timing. Heavily modifying the MAF curve throws all of this out of whack.
To answer your question though:
You can make specific adjustments to individual injector flow rate cells to obtain desired results.
Here is generally what your car is doing for specific MAP. MAP is a direct function of TPS and RPM
0 - 10: WOT
15 - 35: Spirited Driving / Transient
40 - 50: Highway / Mid RPM Driving
55 - 75: Idle / Low RPM Driving / Around Town
80+: Deceleration
Like I said above though. It is best to make block adjustments to the Injector Flow Table, THEN tune WOT with the PE table.
Good Luck,
Kevin
<strong>Also, how are the on-gear and rolling part throttle fuel cells decided by PCM?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">FTC (0-15) is determined by MAP and RPM.
If I don't scale MAP 0-10, does that mean it does not change WOT fueling ? Is there one to one mapping between these numbers and the table ?
If you change your injector flow table for all points other than 0 to 10, then yes your WOT fueling will remain unchanged.
A word of advice though. If your Injector Flow Table has too large of a step (ie there is a 20% difference between the 0-10 MAP and the rest) you can end up causing your car to either hesitate or bog when going WOT. This is another reason it is best to stick with the PE table for WOT tuning.
Good Luck,
Kevin
How about PE vs. flow rate scaling, if you scale WOT flow rate by, say 97%, will the scaling of PE table by 97% maintain WOT a/f ?
Thanks,
Pekka
Power Enrichment is a calculated increase in fuel delivery for WOT. The way the numbers work, a 3% increase in the P.E. table is suppose to be a 3% decrease in WOT a/f. However, in reality it doesn't work that way. As a rule of thumb a 2-3% increase in the P.E. table is equal to 1 a/f point.
For example (on a stock car)
PE value of 1.2403 is equal to about 11.9 a/f ratio
PE value of 1.2403 * .98 is equal to about 12.9 a/f
The injector flow table does not operate on the same principle. You have to "mess" with the table is small percentage steps.
<small>[ November 26, 2002, 08:13 AM: Message edited by: NoGo ]</small>
<strong>In Auto Tap or LS1 Edit, other than monitoring "which" cell it is in, where can you view or revise what the parameters are "in" the cells.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We cannot make specific adjustments to the fuel cell maps (specific fueling tables applied for different fuel cells) other than Fuel Cell 22. Fuel Cell 22 can be modified with the P.E. table.
Fuel Cell 22 is a suedo open loop operation that is applied at WOT and a few other occasions.
