LS1 Edit, What Operating System
Old Nov 26, 2002 | 06:37 PM
ts99's Avatar
Default LS1 Edit, What Operating System
I am considering LS1 Edit. I read where some users are running it with Windows XP. What operating system are most of you using and what problems if any have you had?
ts99
Old Nov 26, 2002 | 09:22 PM
pekkaz's Avatar
Default Re: LS1 Edit, What Operating System
98 here, no probs yet. Some people have had trouble with XP.
Old Nov 26, 2002 | 10:14 PM
felton316's Avatar
I'm using WinMe.... no problem. I think the XP people were having problems using the serial ports. Since all the new computers are going to that legacy free theme.... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Nov 27, 2002 | 04:01 AM
Predator's Avatar
You guys are exactly right, it won't work with XP. I bought a brand new Gateway 600L loaded with XP Professional specifically to use with Edit and EASE, and now I need to get yet another computer (I'm not about to load Win98 on this machine). I should have bought a used laptop in the first place: http://usedlaptopsonline.com/index.html
Old Nov 29, 2002 | 07:39 PM
Ragtop 99's Avatar
So it won't run with XP or is just the no serial port issue?
Carputing says:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">LS1-edit runs on Windows 95, Windows 98, Windows ME, and Windows NT operating systems. Some customers are running LT1/LS1 edit on Windows XP and Windows 2000 systems, but we have not qualified them at this time. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I had win2000 and it worked flawlessly.
<small>[ November 29, 2002, 07:44 PM: Message edited by: Ragtop 99 ]</small>
Old Nov 30, 2002 | 07:18 AM
Predator's Avatar
I originally thought it was a serial port issue, but it turned out to be an XP problem. The software essentially rejects programs not written with XP in mind. The .dll files, and other files, have been "updated" and aren't compatible LS1 Edit, and even EASE (before v2).
Old Nov 30, 2002 | 05:53 PM
red ws6 99's Avatar
ls1 edit works fine on my win xp machine and it does not have serial ports. I dont use a cheep serial to usb adapter though.
Gary
Old Nov 30, 2002 | 06:33 PM
horist's Avatar
i'm running xp no problems... only thing that sux is my laptop doesn't have a serial port, so i was using a USB serial port... but when it lost connection and killed my PCM.. i started using my laptop docking station or my 2nd laptop (older, hard to see display during the day)
Old Nov 30, 2002 | 08:19 PM
02BlueFirehawk's Avatar
I run it with XP Pro. No problems. I got it hooked to the 9pin on the laptop. If there were problems before they must have been resolved. I'm running the latest version of it too.
Old Nov 30, 2002 | 10:43 PM
Predator's Avatar
Edit worked for a couple of months on my XP machine before it stopped working. I hope you XP users don't experience the same plight. Continued good luck!
Old Dec 1, 2002 | 05:13 PM
Ragtop 99's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by red ws6 99:
<strong>ls1 edit works fine on my win xp machine and it does not have serial ports. I dont use a cheep serial to usb adapter though.
Gary</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What usb to serial converter do you use?
Old Dec 1, 2002 | 05:33 PM
LS1-SSS's Avatar
I have Win 95 on my laptop and ME on my desktop. Works fine on both.
Old Dec 1, 2002 | 06:17 PM
red ws6 99's Avatar
I use a four port keyspan usb to serial adapter. I have a wideband 02 on one channel, autotap/ls1-edit on the other. The third port is a programable boost/timing/fuel controller. The last channel is open but will be adding an 8 port egt setup. I have run the o2, autotap, and boost controller at the same time with no problems. the adapter can support 920Kb/s on each channel, more than enough. The one B&B sells made by ionetworks is supposed to work fine also.
The keyspan is half the price of the B&B. Anything from Belkin should be avoided, very buggy.
Gary
<small>[ December 02, 2002, 12:16 PM: Message edited by: red ws6 99 ]</small>
