threw a code(s)
Old Feb 8, 2006 | 04:56 PM
Rothman's Avatar
Default threw a code(s)
Took it to advance auto to have it read. They said both rear o2's are out and one of the fronts too. I have had o2 sims in the rears for about a month now and never set a code before. Is it possible that the diagnostics just saw the sims and figured they weren't working? Maybe just the front? This is what the readout says. I have no idea what it means. Any Ideas?
History DTC P0133
O2 sensor
CTK Slow Response
(Bank 1 Sensor 1)
MIL REQUESTED
Since IGN NOT RUN
Since clear P/F
Current DTC P0135
O2 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 1)
MIL NOT REQUESTED
Since IGN NOT RUN
Since Clear P/F
Current DTC P0153
O2 Sensor
CKT Slow Response
(Bank 2 Sensor 1)
MIL NOT REQUESTED
Since IGN NOT RUN
Since Clear P/F
Verbatim......
Old Feb 9, 2006 | 11:38 AM
Rothman's Avatar
what does the o2 heater circuit malfunction mean?
Old Feb 9, 2006 | 12:13 PM
2001NBMZ28's Avatar
Don't know the answer but your not throwing codes for post cat 02's so the sims are working. I think the bottom description for slow response on Bank 2, Sensor 1 should read P0153? If so, you have current codes for both front 02s.
Old Feb 9, 2006 | 02:58 PM
Rothman's Avatar
your right po153 for the later....
