ls1edit 2k1 and 2k0 PCM
Old Dec 5, 2002 | 06:29 PM
TomQ's Avatar
Default ls1edit 2k1 and 2k0 PCM
I'm having shifting problems with my stock PCM (the car runs ok, but there is this weird feeling between 2 and 3,TM has been deleted), that's why i'm buying ls1edit to update/upgrade my original PCM on the dealership and see if new updates for my car will effect the shifting. But then if it won't help me, it means i bought ls1edit for nothing. So i'm torn between which VIN number i should give to ls1edit guys (2k1 PCM or 2k0 PCM).
I don't have this problem with 2k0 PCM, but the timing tables are different from 2k0 and 2k1, will i be able to move timing tables from 2k1 PCM to my 2k0 PCM?
What PCM i should use,i'm torn
Old Dec 5, 2002 | 06:35 PM
The Derek H's Avatar
Default Re: ls1edit 2k1 and 2k0 PCM
You can compare both files by using the read option for the second file. But I believe you will only be able to read one because it locks to the PCM. Also I have not had much experience comparing files from other years so that might not be possible. When putting the table up the numbers are significantly different in other years. In order to find out first e-mail Ken at Carputing to make sure its going to do what you need it to. Then see if the 00-01 can be combined on the same cable because its only like 100 more for an additional PCM.
