A4 to T56 Conversion
Old Dec 6, 2002 | 01:36 PM
Bowtiecrazzy's Avatar
Default A4 to T56 Conversion
What do I need to do to update the computer on my 1998 LS1 Trans Am to make it work right going from automatic to manual?
Thanks Jeff
Old Dec 6, 2002 | 08:38 PM
68LSS1's Avatar
Default Re: A4 to T56 Conversion
You need to get your PCM reflashed which your local dealership should be able to do.
Old Dec 8, 2002 | 02:44 PM
Ksquared's Avatar
Yes, any dealer can do it... From what I understand unless you know someone, they have big problems in putting a different VIN in the computer of your Car.. The only way they can change the code is by using a VIN from a vehicle with the M6 in that year... If you need it changed, I have a programmer and I have no qualms about doing it... I can only do stock so far...
Kevin
Old Dec 8, 2002 | 04:58 PM
Thanks guys, but does it have to be the same year to use the vin number to re flash it?
Jeff
Old Dec 10, 2002 | 11:39 AM
FASST's Avatar
For a 98, yes. They used a different PCM/wiring harness than 99+. The programming is also different.
Good luck. I did the opposite (M6-A4) over a year ago. The swap is pretty straight-forward.
