#7 cyl misfire need help
Old Dec 6, 2002 | 06:31 PM
CurtD's Avatar
10 Second Truck Club
Default #7 cyl misfire need help
We keep getting #7 cyl misfire and you can feel it and here it 1800 2200 rpms changed evereything. spark plugs, wires,coil, injecter still does it any body got suggestions thanks.
Old Dec 6, 2002 | 06:57 PM
99taws6's Avatar
Default Re: #7 cyl misfire need help
Sounds like a valve spring...or pushrod.. Mine did the same thing with a broken valve spring...
Old Dec 6, 2002 | 08:51 PM
meach13's Avatar
with the bent pushrod or valve spring did it not run bad
Old Dec 6, 2002 | 09:11 PM
Slowhawk's Avatar
LS1Tech Sponsor
You need to to a leakdown test.A few people have had the #7 collapsed ring land problem.The piston could have melted itself.
Old Dec 7, 2002 | 09:48 AM
eallanboggs's Avatar
Sounds like you've already done the obvious stuff. As was recommended a leak down test will find your problem for sure, but if you don't have a leak down tester you can do a compression test. Most people have a compression tester, but a leak down tester is a more sophisticated tool that not everyone has in their toolbox. You could also remove the rocker cover to see if you have any obvious spring problems.
