Question regarding MAFT, 30lb inj, tunning
Has anyone ever got their pcm programmed to run 30lb injectors and ran the stock 28lb injectors with a maft until they bought the 30lb injectors?
I've sent various emails to several people, just trying to draw a solid conclusion here.
Thanks,
Q
Thanks,
Q
Re: Question regarding MAFT, 30lb inj, tunning
Plenty of folks have done the reverse, so it is do able. Drop the injectors in and start at +15 rich and go from there. You may be pretty lean at WOT, so be careful if you don't dial it in. Not an issue if this is a temp measure for few days. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
