disconecting o2 sensor, what happens??
Old Dec 8, 2002 | 02:20 AM
lbz34's Avatar
Default disconecting o2 sensor, what happens??
I am going to use the wideband on my 00 z28. I usually go in at the stock o2 location (on 4 cyl cars). What will the computer do with the b2s1 or b1s1 unplugged??? (Besides SES light). Will it go into open loop like other vehicles (this would be desired). I will weld separate bungs in once the headers are in but in the meantime i would like to get some baseline A/F #'s for reference.
Thanks
Sean
<small>[ December 08, 2002, 02:21 AM: Message edited by: lbz34 ]</small>
Old Dec 12, 2002 | 09:42 PM
Jabroni's Avatar
Default Re: disconecting o2 sensor, what happens??
As long as you play with the rear ones and not the fronts, the only thing you should get is an SES light. Pull the fronts and the car will be totally out of whack. The front O2's are running the show.
