Idle and temp in LS1-edit
Old Dec 12, 2002 | 02:24 PM
The Derek H's Avatar
Default Idle and temp in LS1-edit
The idle table in my LS1-edit program is higher at negative temperatures and decreases at the temperature decreases. When the weather is cooler outside the car idles either erratic or at a couple hundred rpm high. Would it hurt anything to put the same value all the way across the table? Just curious because the car doesn't have any trouble idling at a lower rpm.
Old Dec 13, 2002 | 04:38 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Idle and temp in LS1-edit
I have mine set at all the same rpms from about 0* on up. It's been just fine for me. But I'm not using a stock idle rpm, I'm a couple hundred above stock for the cam...
Old Dec 14, 2002 | 04:37 PM
Ragtop 99's Avatar
won't hurt. Most people like a cold idle to be higher, especially with a big cam.
Old Dec 14, 2002 | 04:50 PM
I was just curious. It seems really high at idle when its cold. The stock a4 idle was around 550 or so and now I have an m6 program since I installed the th400. The stock was around 800 and 800-850 is fine even with the size of my cam. Thanks for the info guys.
