Gauge ?
Old Feb 11, 2006 | 02:38 PM
dws6's Avatar
Default Gauge ?
I have a set of Phantom gauges (black bezel, white face). I am looking for a digital AFR gauge that matches the Phantoms. Any one have any suggestions? Also does anyone know if the Aeroforce Interceptor will accept a wideband input for digital readout. It looks as though it will match.
Thanks,
Old Feb 11, 2006 | 03:54 PM
horist's Avatar
i don't have any experience with the aeroforce one... but so long as it accepts 0-5 volt and your wideband controller can output that it should work...
If it's 0-1 volt (narrowband) you should still be able to use the wideband and configure it to output 0-1 volt only, however not sure how the resolution and accuracy will be
Old Feb 11, 2006 | 08:54 PM
dws6's Avatar
Yeah, I have no idea if it accepts a 0-5v input or not, I would have to call. Just wanted to see if anyone here knows. Also I am using a PLX M300 I dont think it has the 0-1 volt unless you mean the simulated narrow band that is running to my PCM input. That still wont give me the digital AFR I'm looking for right?
