Injector Offset for 60lb mototron injectors
I'm installing a A&A P1SC on my Z06 and I have upgraded to the 60lb injectors as well. I'll also be swapping my cam out to a Futral F7 224/230 114+4 but if there are tuning issues then maybe I should just stick with the stock Z06 cam?
Originally Posted by EC_Tune
The other issue could be your DFCO Entry RPM as you have to be above the entry RPM to enable DFCO. You may want to try lowering this value to say ~1600-1700 RPM
EC
EC
Dixit
Did you put your DFCO MAP settings back to stock with the RPM entry lowered?
If so then:
I guess it's time to call/email/fax Mototron and show them the table you are working on and see if they have the data. If not, they shouldn't be manufacturing injectors.
If so then:
