2 step help!!!
Old Feb 12, 2006 | 01:48 AM
1badV6's Avatar
Default 2 step help!!!
Which wire is the clutch signal on the pcm. What about the wires from the 2 step. How you running your setup? Anybody?
Old Feb 12, 2006 | 02:25 AM
HumpinSS's Avatar
I have the latch hooked up to my trunk release switch and if search was working i would tell you the clutch signal wire. When it comes back search for PCM PINOUT
