99 Bolt on C-5 LS1Edit Dyno numbers!!
Old Dec 17, 2002 | 10:26 PM
Mike TexaSS's Avatar
8 Sec Tuner
Default 99 Bolt on C-5 LS1Edit Dyno numbers!!
Ill get straight to the numbers.
Before LS1 edit with FLP Long tubes, Blackwing Cold Air and B&B PRT cat back.
333.6 RWHP
337.1 RWTQ
After LS1 edit with above mods plus removed the cats and added a 180 deg thermostat.
343.9 RWHP
356.3 RWTQ
Any questions? <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" alt="[Z06 Corvette]" title="" src="graemlins/z06.gif" />
<small>[ December 18, 2002, 12:23 PM: Message edited by: Mike TexaSS ]</small>
Old Dec 17, 2002 | 10:52 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: 99 Bolt on C-5 LS1Edit Dyno numbers!!
Did you happen to do before and after Cat dyno'ing?
The reason I say this is because I saw a loss of 15hp/20torque on the dyno by just installing the Cats on my FLP's <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Dec 17, 2002 | 11:01 PM
8 Sec Tuner
My before and after numbers are about 6 months apart.
On 6-22-02 with air intake temp 92.5 deg it dynoed
332.9 RWHP
333.6 RWTQ
Then today 12-17-02 with air intake temp 72.5 deg w/o cats no other changes from last dyno numbers.
335.6 RWHP
348.0 RWTQ
I gained tourque but i dont know if it was from the cats or air temp. But the car is too loud and i will be putting the cats back on.
Old Dec 18, 2002 | 05:14 PM
niphilli's Avatar
What was changed with Edit? Were you rich? Did your timing look bad? Any KR before edit? I think it is pretty typical to see 8-10 RWHP in taking off cats with FLPs. Your pre-edit numbers with cats look identical to my numbers with cats.
-Nick
Old Dec 19, 2002 | 12:22 AM
8 Sec Tuner
TTT <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
