Help 4.10 gears A4 car and HPP3 what shift points
My car is shifting at 5 MPH and 15 MPH when i leave from a stop during normal driving. I switched the gear for the computer using HPP3 but i need to fix the shift points. What shift points should i be setting it at. REV limiter is set at 6300 RPM and its just a bolt on car.
<small>[ December 19, 2002, 05:39 PM: Message edited by: sited12 ]</small>
LOL, I think you mean what shift points. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> (see the title of the post, hehe)
Anyway... with the rev limiter set to 6300, then shift points I would say should be at 6000 or 6100.
Sorry about my profanity in the title. So if i went at 6100 RPMs what is the formula for how many plus or minus it is with the HPP3. Right now im in forth gear by 30 MPH.
I believe the hpp3 Programming is only active at WOT. My car shift's normally around the same MPH as you stated. I have my rev limiter set to 6200 and 1-2 +2, 2-3 +3, 3-4 0. I leave my car in D at the drag strip and I don’t hit the limiter in the 1/4. Hope this helps!
<small>[ December 20, 2002, 09:18 AM: Message edited by: 02Z ]</small>
