Headers Glowing Orange!!!
B&M Ripper shifter
Eibach Lowering Springs
CAGS! skip shifter
Accel Race Wires
T-Ngk plugs
Slp Loudmouth
Air Temp Mod
SLp fan switch
Whisper Lid/k&n Filter
Fast Toys Ram Air system
MAFT and MAF ends
TB bypass and EGR mod
JBA headers
Stage III star clutch w/ MMS aluminum Flywheel
2001 HM hydrolics
Drill Mod
Polly Tranny mount
<small>[ December 23, 2002, 04:46 PM: Message edited by: VentsWoker ]</small>
<strong>your car is runnin super lean dude. either that or i've heard that clogged cats can make them glow as well. ditch the cats or fix the air/fuel and it wont do that. unless you just want it to ;D</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ya, thats what i'd guesss, but i have never heard of that before except on turbo cars <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
p.s. all the dip switches are down <img src="http://hometown.aol.com/xvx7773/myhomepage/personal.html" alt=" - " />
Everyone else is right on though... you are VERY lean, at least at 17:1....
<strong>MAF-T will NOT do that. The only way that can happen is if you are coming off WOT and are in PE, or if you are in open loop..
Everyone else is right on though... you are VERY lean, at least at 17:1....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Like said above MAFT is only messing with WOT mixture. At idle it will no do anything
Everyone else is right on though... you are VERY lean, at least at 17:1....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Like said above MAFT is only messing with WOT mixture. At idle it will no do anything. First check obvious stuff: Plugs, Wires, Cats. Then you should look into a diagnostic device and a tune.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> MAF-T will NOT do that. The only way that can happen is if you are coming off WOT and are in PE, or if you are in open loop..
Everyone else is right on though... you are VERY lean, at least at 17:1.... </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by niphilli
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Like said above MAFT is only messing with WOT mixture. At idle it will no do anything </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do either of you own a MAFT? Mine has Base settings and WOT settings.
there's nothing to cool the headers. The glow
is just more obvious in the dark. I've seen
this on cars of mine that had headers, without
any special problem being present. Same for my
motorcycle, if it sits and idles high for a
bit the down tubes glow.
Mixture will change exhaust gas temp, but a
gross mixture error isn't necessary to see
some glow, in the dark.
<small>[ December 24, 2002, 02:47 PM: Message edited by: jimmyblue ]</small>
