ENGINE LIGHT ON
Old Dec 28, 2002 | 11:41 AM
Jalbert's Avatar
Default ENGINE LIGHT ON
Can anyone help me to get my engine light to go off I went and started my motor while all of the plugs on yhe air intakes were disconnecred and the light came on I've tried disconecting the battery but no luck help please.
Old Dec 29, 2002 | 01:01 PM
NoGo's Avatar
Default Re: ENGINE LIGHT ON
If you don't feel like pulling fuses, disconnect the battery and leave it off overnight.
Old Dec 29, 2002 | 08:53 PM
Gev's Avatar
Gev
Make sure your car is in the "on" position but dont start the car. Open youre engine compartment and take out the PCM IGN and PCM BAT fuses and leave them out for 5 minutes. Turn the ignition off. Replace the fuses and start your car.
--->>> When i did this, the car would start and it would die again. If it does this, no worries, keep your foot on the pedal and give it some gas, let go and see if it idles. If not, try again. Repeat until the idle is normal.
