About to attempt first LS1Edit burn, could someone look over my changes?
Hey Guys,
I just got edit a couple of weeks ago. I've removed EGR and AIR and have Headers and a 160 Thermo.
So my goal for my first burn is to take care of the obvious before concentrating on increasing performance. I've been throwing EGR and AIR codes since removing them. I'd like to pull off my CAGS eliminator and O2 sims and naturally I don't want to throw anymore codes.
So here's what I've done so far. Please look over my changes and tell me if I'm doing the right stuff.
Trans Calibration:
-M6 CAGS(I set 'speed in MPH' enable to 255 and disable to 0, I didn't touch load, enable temp I changed to 255, and %TPS to disable to 0.)
Engine Cal:
-EGR(I have no idea what VSS stands for, but I set enable to 250 and disable to 248. I also set EGR Enable to false.)
-Air Pump(It says coolant diable temp is -10.2, but I have no clue what this is referring to. What do I need to change here? Also is there a way that I can stop the AIR pump fan from spinning when the engine starts up?)
System Calibration:
-Fans(There are different values here for the first and second stage fans, but I'm not sure what to set them to for a 160 thermo?)
-What is PRNDL equiped? It sounds like it stands for Park, Rev, Neutral, Drive, Low, but I have an M6 so why would this true?
Speedometer:
-Speed Limit(Set this to 255, What is electronic
throttle and hysteresis?)
Engine Diagnositics:
-Hardware Diagnostics(I made several changes in here)
*P0401 EGR Perfomance(toggled to off)
*P0404 EGR Pintle Postion Error (toggled to off)
*P0405 EGR Pos Sensor Low Volt(toggled to off)
*P0410 AIR System(toggled to off)
*P0412 AIR Solenoid Relay Control Circuit (toggled to off)
*P0418 AIR Pump Relay Control Circuit(toggled to off)
*P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit (M/T)(toggled to off)
*P1404 EGR Pintle Closed Position Performanc (toggled to off)
*P1415 AIR System Bank 1(toggled to off)
*P1416 AIR System Bank 2(toggled to off)
I know this is a bunch of stuff to go threw. I just wanted to know if I was altering all of the right areas. The only area I haven't hit is the rear O2 sensors. What do I need to alter to be able to get rid of my sims?
Thanks so much to anyone who takes the time to read threw this and let me know how I'm doing so far.
Later,
Mike
Trans Calibration:
Engine Cal:
System Calibration:
Speedometer:
Later,
Mike
OK I was doing a little searching and found the following post:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by chuckster:
<strong>
Find the Following Codes
Delete Rear O2 Codes
0137,0138,0140,0141
0157,0158,0160,0161
Then on the SES tab set them to off
Then on the Error mode set it to X= turned off </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So Add these modifications to my list and also I went through and altered the error mode of each of the hardware diagnostics parameters that I altered above.
Mike
<strong>
0137,0138,0140,0141
0157,0158,0160,0161
Mike
Happy New Year <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Looks good, the only thing I can think off it under Engine, test parameters turn EGR enabled to False. Other than that it looks like you got it covered. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Good Luck
I know that was a lot to read over, it was however appreciated <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Thanks bro.
Mike
Mike
