idle drops to 500...
Any solutions yet for you??
displays 200/199, so no cracker action for you. May
want to get it back in play and make more of a
linear taper to it, not the big "ridge" to stumble over.
The AIR! System is removed I believe, but at start up you can hear something running and it turns off at 100 degrees during warmup. When it turns off the car dips, my tuner said it was the AIR system shutting down.
man after being spoiled with hptuners 2.x I don't think I could do edit anymore.The Best V8 Stories One Small Block at Time
So the pump is still in the car and all though it isn't connected (mechanically) it isn't disabled (electronically). Therefore, it is causing a draw on the electrical (alternator) which is adding drag to the engine.
I set mine to only come on when my ect exceeds 284 (never I hope).
I am curious about this problem also as I am running SD and I have this problem as well.
I drilled out the hole in the TB to one step larger bit and backed the idle screw all the way out. I checked my IAC and it was at like 130 step at idle. I drilled a second small hole (same size as stock) in the TB below the other hole. Checked the IAC and it was 60 step at idle. I opened it up more (same size as the other whole) and got it to 15-25 step at idle. Now when the IAC drops (which is why your idle is falling off), the IAC bottoms at 0 but the car only dips to like 900 rpm and never stalls. I think that this problem is related to the lean condition that some people are talking about at warm start while running in SD. This is a patch but it works great for me.
PLease look at what I am running in my sig. You will likely not need to make the second whole as my 402 probably needs more air.
Now, if I could just get rid of the bucking between 1600-1900RPM, I would be all set. I got my VE tables between 0 and -3 and it wont go away. This may need some of that throttle cracker action that some speak of. I just don't know how to work that yet with my HPTuner. One step at a time I guess.
After swapping out the intake, all of the major idle jumps went away. But the car still has major dipping issues. Everytime I decelerate now, and get below 10 mph or so the car dips to 600 or so RPMs. Also ALOT of times when I take it out of gear when coming to a redlight or stop sign, as soon as I disengage the clutch the idle will dip and come back up. 90% of the time though when I slow down it happens. Could it be the throttle body was ported to much? Or the screw not set properly?
