need help with A4
Old Jan 16, 2003 | 10:46 PM
cobrakilla's Avatar
Default need help with A4
i just got a new tranny A4 and i am trying to get the car to shift at 6400 rpm. i keep bumping the limiter on 1-2 shift and 2-3 shift. does anyone have a formula or have a table i can follow to enter the right mph for 6400 rpm shifts. i cant use my TNT until i get this shifting problem solved. if it helps to know, my car has 3.73 gears, 3200 stall,26x10.5x16 e.t. streets. thank you.
Old Jan 16, 2003 | 10:53 PM
98TAauto's Avatar
Default Re: need help with A4
1st gear 1MPH = 129 RPM and 2nd gear 1MPH = 69RPM
or you can just set say the MPH low and use the RPMs to get her shifting where you want or VICE VERSA... both have to be meet for the car to shift and also keep in mine A4's lag on there shifts
Old Jan 16, 2003 | 11:49 PM
cobrakilla's Avatar
sorry but i still cant figure it out.can anyone post what they shift at 6400rpm or 6500 rpm with similar mods.its driving me nuts. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Jan 16, 2003 | 11:58 PM
Cartier1's Avatar
are you programing with ls1 edit??
Old Jan 19, 2003 | 08:37 PM
2000WhiteZ28's Avatar
I think what 98TA is saying is try this:
desired shift 6400 rpm minus 50 for lag = 6350
6350 divided by 129 = 48.8mph.
1st gear set to 49mph and 6350 rpm
6350 divided by 69 = 92.0mph.
2nd gear set to 92mph and 6350rpm
I think I used 100 for my lag, but my points are very close to the above. I also have 6600 rev limit which I do not hit. Keep in mind, I did this on Predator not edit.
Old Jan 19, 2003 | 08:39 PM
If you are using TNT you may want 150 to 200 lag, maybe more with TC. You'll have to try it out.
Old Jan 21, 2003 | 01:01 PM
CPC Racer's Avatar
What would the factors be for 3.23's?
I have been hitting the rev limiter on the 1-2 and 2-3 shifts, so I finally broke down and bought the Predator. Should be getting it sometime next week.
TIA!
