Factory Rev Limiter???
Old Jan 19, 2003 | 10:20 PM
BoneStock's Avatar
Default Factory Rev Limiter???
What is the factory Rev limiter on a 2002 LS1. I have heard so many different things. My car hits the limiter at 5800 rpms, according to the tach. Also I have heard 6200. If that's the case then my tach is off. And also what is everyone shifting at? The car is stock with a lid, filter, and MAF sensor. Thanks for any info <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jan 19, 2003 | 10:25 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Factory Rev Limiter???
I have seen the factory PCM file for a 2000 LS1 F-car. Rev limiter was 6200rpm. Not sure if '02 is any different.
Your tach is most likly off. Most of them are.
Old Jan 20, 2003 | 08:25 AM
2000WhiteZ28's Avatar
Your tach is lagging behind actual RPM's. They all do it. With a tuner prgram you can see actual RPM's from the ECM.
Old Jan 21, 2003 | 08:40 PM
ArcticFormula's Avatar
To the top, I am curious as well. And what rpm should my 2002 A4 be shifting at WOT.
Thanks in advance.
Old Jan 21, 2003 | 08:59 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ArcticFormula:
<strong> To the top, I am curious as well. And what rpm should my 2002 A4 be shifting at WOT.
Thanks in advance. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you have stock tuning, it should be shifting right after you bounce off the rev limiter on the 1-2 and 2-3 shift.
Old Jan 21, 2003 | 09:07 PM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
The stock flash file for my 2001 Firehawk has the rev limit at 6,200 rpms.
(stock 3.23 gears)
The shift points are:
1-2 37 MPH 6,000 rpms
2-3 76 MPH 6,000 rpms
3-4 125 MPH 5900 rpms
