Is is possible to change the O2 Heater Circuit temp range with Edit?
I'd like to prevent this code from showing. I'm pretty sure the temp change is from the sensor positions in the exhaust stream so I'd like to mess with the temp parameters so I don't have to keep clearing the O2 Heater Circuit code.
If the location isn't causing the code, and I don't have a leak (checked a couple of times) what else could I attempt? If Edit can't fix it that is.
Thank You!
