2 bar ?
Old Feb 16, 2006 | 09:42 PM
STALL UP's Avatar
Default 2 bar ?
what is the difference between 2 bar and 1 bar and would you recommend it for a procharged 346 8-9 psi?
Old Feb 17, 2006 | 12:37 PM
horist's Avatar
2 bar can accuretly measure 0 to 200kpa (100kpa ... well actually I think 101 or 102... is 1 atmosphere)
so 0 to 100kpa is 1 atmosphere meaning 0 is complete vacuum, 100 is lack of vacuum (cylinders fully filling)
when you go into boost you're overfilling the cylinders. 8-9psi would be in the 2 bar range (it'd be around 160kpa I think)
The stock computer can't accuretly measure this overfill (boost) w/the MAP sensor since it maxes out at 1 atmosphere.
However, just putting a 2 bar sensor in isn't enough... you need a custom OS (Such as HP Tuners offers) to gain the VE (Volumetric Efficiency) resolution to safely tune it.
Or you can keep the MAF, however I believe that's getting close to the max amount of air the stock MAF can measure...
So basically the 2 bar in your situation would be for if you want to run a speed density tune w/a custom Operating System.
Old Feb 17, 2006 | 01:11 PM
jyeager's Avatar
I'm not entirely sure you will be maxing out your MAF. If not, then you just retune...
If so, then you need to do what horist said.
Old Feb 17, 2006 | 01:54 PM
HumpinSS's Avatar
At 8-9 psi he will start running out of frequency or getting real close to 12000 hz. EFILive also offers a 2 bar solution
Old Feb 17, 2006 | 02:44 PM
RedHardSupra's Avatar
i maxed out MAF at 4800RPM on a STS car with stage 1 heads, LT headers, and 5psi. MAF quickly becomes a problem if you go FI.
Old Feb 17, 2006 | 04:24 PM
STALL UP's Avatar
the tune I have know makes good power and drives pretty good with stock maf so I was wondering is it worth the money to change to 2 bar and is it safer/more power for the car.
Old Feb 17, 2006 | 04:39 PM
horist's Avatar
if you don't max the MAF then you're probably fine so long as your MAF isn't too far off (if it is then it can be tuned in)
But if you're getting close to maxing the MAF then you definetly should consider 2 bar
Theoretically a 2bar Speed Density tune would make more power over an equal MAF tune since you eliminate a restriction ... but I haven't seen any side by side dynos to demonstrate how much more power (if it's even noticable)
Old Feb 17, 2006 | 04:59 PM
STALL UP's Avatar
how would I know when the maf is maxed out?
Old Feb 17, 2006 | 05:05 PM
HumpinSS's Avatar
you will get a ses light p0101 or p0103
go wot, look at the graph, at one moment MAF will just flatline at 512g/sec (IIRC)
Old Feb 17, 2006 | 07:12 PM
STALL UP's Avatar
Is there anyway for me to look at my tune and be able to determine if it is maxed out.
Old Feb 17, 2006 | 07:57 PM
2valve, stock headed/cammed (shitty 80% VE) revving to 6600rpm, running 9psi on 5.7 should flow about 857cfm=65lb/min=490g/sec of air.
that's not too much actually...hmm...
Old Feb 18, 2006 | 04:31 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Who cares if the maf maxes or not? With the better throttle response I obtained when I ditched the maf, I wish I had done it sooner, although I did wait for it to max out first.
