Everyone with ported MAF ends
Old Jan 27, 2003 | 11:43 PM
98TAauto's Avatar
Default Everyone with ported MAF ends
What did you do or learned how to do now from all the posts to get your car in tune from ported ends??
I know when I had mine on the LTRIMS were around +20ish
what can you do to get them down to -3 or so??
I just dont like the IDEA of maxing my MAF table out to get them close to zero
Old Jan 28, 2003 | 06:54 AM
99taws6's Avatar
Default Re: Everyone with ported MAF ends
I have used my MAF table to fix my +15 numbers. I have no knock or any adverse problems.. If you find a better way, let me know..
Old Jan 28, 2003 | 09:19 AM
DailyAluminumBlock's Avatar
Reduce your injector flow rate table. If you skew your maf table too far you will loose timing. I did, but as soon as I changed my injector flow rate table and put my maf table back to stock my timing jumped right back up.
Old Jan 28, 2003 | 09:54 AM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DailyAluminumBlock:
<strong> Reduce your injector flow rate table. If you skew your maf table too far you will loose timing. I did, but as soon as I changed my injector flow rate table and put my maf table back to stock my timing jumped right back up. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">wouldnt you increase the IFR table to flow more fuel to richen the car up?
Old Jan 28, 2003 | 05:57 PM
Doc99SShome's Avatar
I re-calibrated the MAF table with LS1Edit to get ris of +22% LTFTs. I have had no drivibility problems (M6) and I am pulling 28* timing at WOT.
The idle is smooth and steady with a 218/218 cam.
I dont know what you mean by "maxing out the MAF table".
Old Jan 28, 2003 | 06:09 PM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Doc99SShome:
<strong> I re-calibrated the MAF table with LS1Edit to get ris of +22% LTFTs. I have had no drivibility problems (M6) and I am pulling 28* timing at WOT.
I dont know what you mean by "maxing out the MAF table". </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ok say my LTRIMS are roughly 20
Say I mult the MAF table by 120 to get them to zero, wellll it wont let me because I guess the MAF doesnt let you tune that high??
I think the highest I can Mult the whole MAF table by is 118%
Old Jan 28, 2003 | 11:50 PM
felton316's Avatar
You do not want to multiply the entire MAF table by the same percentage. The graph is not a straight line, so when you increase everything by 118%, some parts of the table are going to be affected more than others. Also, the the IFR is done the opposite of the MAF table. You want to decrease the IFR to flow more fuel. I think that number represents the time between pulses, so by decreasing it you're adding more fuel.
When I put my ported MAF it made my Ltrims +5, so I tweaked my MAF table. I started off by multiplying the values from 1500-6000Hz by 108%, then started to decrease the % the higher I moved up in the Hz, until it finally got to 100%. It made the curve much smoother and didn't garbage up the high end of the MAF table.
If you have to adjust the MAF by a large amount, then I would try tweaking the IFR so the MAF will not be too far off.
Old Jan 29, 2003 | 09:35 AM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by felton316:
<strong> You do not want to multiply the entire MAF table by the same percentage. The graph is not a straight line, so when you increase everything by 118%, some parts of the table are going to be affected more than others. Also, the the IFR is done the opposite of the MAF table. You want to decrease the IFR to flow more fuel. I think that number represents the time between pulses, so by decreasing it you're adding more fuel.
If you have to adjust the MAF by a large amount, then I would try tweaking the IFR so the MAF will not be too far off. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks alot for the info!!
Old Jan 29, 2003 | 07:02 PM
When I re-calibrated my MAF table, I did not multiply thru by the amount of the LTFT across the entire table. This is not the way to do it.
You have various fuel cells. There is a unique LTFT value for each fuel cell, also these fuel cells can be linked to specific ranges of the MAF table.
In order to re-calibrate my MAF table, I broke the table into three ranges of frequency and treated each ranges separtely. The top range (8,000Hz and above was multiplied by 104%, while the idle (and just off idle range (1500 to 3000Hz) was multiplied by 115%. I am typing these numbers by memory, so they be off a bit.
If you multiplied thru by 120%, you did it all wrong (IMHO), unless of course, every LTFT value in each fuel cell was +20%. Even then, I would have mutiplied thru by 115% for my first attempt because I am a little conservative on my changes.
