new to EFIlive
36.131012
36.365121
36.599232
36.833342
37.067452
37.223526
37.457636
37.691747
37.925856
38.081930
38.316040
38.550150
38.784260
38.940334
39.174445
39.408554
39.564628
30# SVO @ 43.5psi
34.646988
34.871482
35.095977
35.320471
35.544966
35.694630
35.919123
36.143618
36.368112
36.517776
36.742270
36.966765
37.191259
37.340922
37.565417
37.789911
37.939574
42# @ 40 psi
50.583416
50.911170
51.238925
51.566678
51.894433
52.112937
52.440690
52.768445
53.096199
53.314702
53.642455
53.970210
54.297964
54.516467
54.844222
55.171976
55.390479
42# SVO @ 43.5 psi
48.505784
48.820075
49.134368
49.448659
49.762953
49.972481
50.286773
50.601066
50.915357
51.124886
51.439177
51.753471
52.067762
52.277291
52.591584
52.905875
53.115404
Table that needs to be adjusted is B4001. If you have 30#'s now and your IFR table shows 32lb, it is wrong. You will need to input the correct IFR table and correctly retune the VE/MAF tables to reflect the new injectors.
what would the 42's be at about 55-60psi
If the injectors are flowed at 43.5 psi he gave yo the numbers for what it would be at 58 psi for our cars if they were flowed at 40 psi he also gave the 58 psi equivalent for our cars. The numbers you are looking at are grams/sec he posted umbers in lbs/hour
so the 43.5 numbers are what I would use???
-Geoff
