Hp Tuner Help
If so, here are my mods.
1998 z28 A4
Stock bottom end
Prc ls6 cnc ported heads (stock valve size)
MS3 on a 113 LSA
Stock rockers
Ls6 intake
42 lbs injectors
Ported throttle body (idle hole is already drilled bigger)
MTI air lid
smooth bellows
pacesetter lt's
TSP 3" ORY
TSP rumbler catback
Electric cutouts
yank ss 3800 stall
4.11
150 wet shot of NX
Also it is hypertech programed right now, will i have to remove that?
Thanks
Stephen
I am using other tunes and comparisons to educate myself on tuning.
not find an entirely identical tune file. But taking someone
else's file, you won't know what's buried in it. I recommend
you work through things methodically and keep notes, that
is a lot of stuff to get through.
As it happens, this weekend sometime I'm going to be trying
to deal with a similar setup (but on an '02) so I may have
some good chunks for your stew, later.
How can you be running on 42lb injectors and a big cam,
with only a Hypertech tune? Seems unlikely; was this car
tuned before and then you laid the Hypertech on top of
that?
On a side note, you'll definitely need to change some basic things if your putting a new cam in and changing injectors.
Good Luck!
