Computer problems with aftermarket converter?
Old Jan 31, 2003 | 08:21 AM
Red TA's Avatar
Default Computer problems with aftermarket converter?
Are there going to be any pcm problems if I install a ST-4000 converter on my 2002 LS-1 TA?
Old Jan 31, 2003 | 08:37 AM
98TAauto's Avatar
Default Re: Computer problems with aftermarket converter?
you shouldnt have any.... people run 4400's with no issues...
the only thing I can think of that MAY/COULD happen later down the road is issues where the converter locks and unlocks from misfire codes. Its usually from running ported ends.. I had to set my misfire temps to like 140 and 139 so the converter didnt unlock while I was driving normally...
but you will be fine.. just get the converter and have fun <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jan 31, 2003 | 08:42 AM
Red TA's Avatar
I think that i have read where the aftermarket converter would lock up to early because the computer thought that is was slipping too much. Ever hear of this?
Old Feb 3, 2003 | 06:30 AM
Red TA's Avatar
Anyone heard of this?
Old Feb 3, 2003 | 08:26 AM
ANIL8U's Avatar
I have an 02 with a vig 3200 and the only problems I have is in cold weather my conveter will not lock!
Old Feb 3, 2003 | 11:57 AM
Killer '01 SS's Avatar
I have an '01 with a TCI 3500 stall converter and was getting a P0757 code ("2-3 shift solenoid stuck open") until I deleted the PCM's detection of that code with LS1_Edit. I was told that this code tends to pop up on '01 and '02 cars when a loose converter is installed. Just a heads up! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 16, 2003 | 05:06 PM
numbZ's Avatar
I put a vig 3200 in my `02 Z with no problems.Only thing I plan on doing is deleteing torque management.
Old May 17, 2003 | 01:01 AM
pascal's Avatar
i am about to but in a vig3200 also with a transgo shift kit. what happens and how do you delete torque management???
Old May 20, 2003 | 01:38 PM
WS6 RULES's Avatar
I have 2002 also. When I e mailed Yank they told me I would have problems with a high stall like a 4000. I think his name was Mike. Said I should stay around 3000 or less or I would need reprogramming.
Old May 24, 2003 | 05:22 PM
GrannySShifting's Avatar
thats not exaclty accurate. You may need some computer tweaking but its nothing 1000s of peopel havent already done.
Id stay away from peopel who recommend less than a 3000 stal in a ls1 car
