A/F & Timing
Old Feb 18, 2006 | 05:37 PM
minytrker's Avatar
Default A/F & Timing
How lean is still safe on a z06? My car is at 12.7 right now at wot with 25-26 deg of timing with 0 knock retard. Will I gain any power from leaning it out to 13.0 and adding 1 or 2 deg of timing. To lean it out at wot do I adjust PE Modifier Based on RPM? It is .86 right now from 3200rpm on up? I am still learning about tuning and am using EFI Live if that helps.
Old Feb 18, 2006 | 05:39 PM
hellbents10's Avatar
LS1Tech Sponsor
I would keep it right there. No need to get leaner or add more timing, keep it safe and have fun. You might be able to get a couple of degrees out of it or lean it out up top. DO not take away any fuel before or at the torque peak.
Old Feb 18, 2006 | 05:50 PM
minytrker's Avatar
I am trying to get another 10rwhp or so. My car put down 377/371 and the norm seems to be 385 with alot of people even seeing 395rwhp. I know you can't feel 10 hp but it sucks to do mods and everything and end up short.
Old Feb 18, 2006 | 06:44 PM
white2001s10's Avatar
Go ahead and try adding advance while leaving the fuel the same. Often an increase in spark advance will show leaner on your wideband, so you'll get the effect you want without actually pulling any fuel.
How the engine responds depends on the entire combination and what it wants. The best way is to try it an measure power difference. See what the engine wants.
Old Feb 19, 2006 | 03:30 AM
minytrker's Avatar
I will try 2 more deg and see what happens. Should I just adjust from say 4000rpm on up? Where can I see what Oz/Cylinder range I should change?
Old Feb 19, 2006 | 08:10 AM
Doc's Avatar
Doc
Log some data with the scanner with the pids you want. In this case select or highlight the wide open throttle section of the log and then open the tuning tool and bamo the affected cells are laid out for you. I hope the screen shots turned out ok. I had to resize them down to 100kb a piece to get uploaded. I just used the HO spark table in the tuning tool as an example. You can do this with any of your tables, values.
Attached Thumbnails A/F & Timing-sparkadj2.jpg   A/F & Timing-sparkadj1.jpg
Old Feb 19, 2006 | 01:02 PM
WS6FirebirdTA00's Avatar
i run mine in the low 13's i know a lot of people that pick up some power going high 12's to low 13's, anywhere from 5-10, but that depends a lot on the car as well
Old Feb 19, 2006 | 05:53 PM
minytrker's Avatar
Thanks, that helps alot. I didn't know you could do that.
