LS1edit and turbos
Old Feb 4, 2003 | 07:23 PM
70 LS1's Avatar
Conversion master
Default LS1edit and turbos
Can LS1edit be used to tune for a turbo or supercharger?
Old Feb 5, 2003 | 06:09 AM
Camaroholic's Avatar
Default Re: LS1edit and turbos
Errrr, there is no "click here if you have a blower" button, and it does not change things enough so that you can run a multi-bar MAP sensor, but yes, it allows you to change fueling and spark tables. You can pull timing, add fuel, etc. So yes, it can be used. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Andrew
