Predator on a M6
Old Feb 6, 2003 | 10:59 AM
2_wacko's Avatar
Default Predator on a M6
I am very new to the Predator i was wondering if someone could take the time to explain a little about this product. First does it help a M6 or a A4 better. Also What are the up and downs having it on a A4 and a M6. The only mods i have are a Cutout and a 80 series flowmaster.Should i expect better performance with the Predator.
2002 Sunset Orange Z28 cutout and 80 series Flowmaster. I want to change to SLP Loudmouth.
Old Feb 6, 2003 | 04:16 PM
WJ SOM SS's Avatar
Default Re: Predator on a M6
Click on to "Diablo Sport" site on your right. They're a sponsor here and it's all on their site. Best wishes. WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 25, 2003 | 11:51 PM
DiabloSport Products Informant's Avatar
That isn't "DiabloSport". They are just a distributor.
Here is the real information he seeks:
- 30-Day Satisfaction Guarantee!
- Lifetime Warranty!
- Screen Size is 300% larger than the competition
- Custom Files can be downloaded from internet which allows for future updates
and customized programming (handheld competition does not offer)
- Quicker programming than the competition (takes approx. 2 min.)
- OBD-II diagnostic software (includes live data monitoring of MPH, RPM, IAT, ECT, LTFT, STFT, O2 Voltage, Timing, KR detection, as well as many other sensors (competition does not offer)
- Revised Torque Management Settings for optimum performance
- Eliminates CAGS (Skip Shifting) on the 6-speed manual transmissions (GM)
- User adjustability. the user can set their own parameters. Choose from DiabloSport's performance program, have a custom performance program made for you by a DiabloSport tuner, or modify the performance program your own:
- Axle Ratio: Can adjust from a 2.xx up to a 6.xx in .01 increments.
- Cooling Fans: Will adjust both ON and OFF in 1 degree increments up/down.
- Power Enrichment (Fuel): Will adjust from -5% to +5% at WOT
- Spark (Timing): Will adjust from from -10% to +10% at WOT
- Shift Adaption (duration): Allows user to adjust the time delay during the gear change, i.e. quickness of the shift, from -25% up to +25%
- Shift Points (MPH): Allows user to adjust at what MPH the shift should take place, for each individual gear, in 1 mph increments.
- Shift Points (RPM): Allows user to adjust at what RPM the shift should take place, for each individual gear, in 10 rpm increments.
- Shift Pressure: Allows user to adjust the firmness of the shift action, for each individual gear, from -25% up to +25%
- Rev Limit: Allows user to adjust ON/OFF rev limits, for each individual gear, in 10 rpm increments.
- Wheel Sizing:
-- Factory Wheel Size: Enter the factory tire size in XXX/XX-XX format, i.e. 275/40-17
-- Actual Wheel Size: Enter the actual tire size in XXX/XX-XX format, i.e. 305/35-18
The Predator then calculates the difference in overall height for proper speedo calibration.
You can purchase this unit from a DiabloSport "retail" dealer such as Speed, Inc. www.ls1speed.com
Old Mar 26, 2003 | 12:12 AM
Bear's Avatar
Couple questions. Can the Diablo but used on 2 different cars AT ONCE. I have 2 cars that will need tuning so to speak. Also can u input a selected cam. That would help. I know this isn't LS1 Edit, buttttt. Thanks.
<small>[ March 26, 2003, 12:15 AM: Message edited by: Bear ]</small>
