weirdness in the Throttle Cracker; stalling fix.
Old Feb 19, 2006 | 12:05 PM
jimmyblue's Avatar
Moderator
Default weirdness in the Throttle Cracker; stalling fix.
In tuning on a car ('02 Trans Am) last night I came across
an ugly/weird looking Throttle Cracker Airflow table (see 1st
.gif). I was trying to alleviate a stalling problem that was
seen with throttle blips / braking w/ low throttle.
This is apparently present from stock, it's in my original tunes.
The table just looks wrong; big follower air where you would
think you need none, and zero air added right where you need it
most.
I eyeball-smoothed it (see 2nd .gif) and it seemed to eliminate
the stalling, at least I got a phone call to that effect from the
road on his way home.
Attached Thumbnails weirdness in the Throttle Cracker; stalling fix.-throttlecrackerairflowfu2.gif   weirdness in the Throttle Cracker; stalling fix.-throttlecrackerairflowfixed2.gif
Old Feb 19, 2006 | 12:08 PM
WS6FirebirdTA00's Avatar
all the issues i was having i zeroed out my throttle cracker table and it really helped the car out
Old Feb 19, 2006 | 12:25 PM
TAQuickness's Avatar
I've had to do some intersting masage therapy on the cracker/follower tables to get my idle transistions under control as well.
Old Feb 19, 2006 | 12:29 PM
2xLS1's Avatar
Those holes in the table are only on 00-02 A4 cars. 98-99 A4 tables don't have them or neither do any year M6 car tables.
Old Feb 19, 2006 | 12:30 PM
here is what i had to do to mine. i was quite amazed at how much better the car came to idle
Attached Thumbnails weirdness in the Throttle Cracker; stalling fix.-throttle-cracker.jpg
Old Feb 19, 2006 | 01:22 PM
Josh's Avatar
Is there a standard method for tuning the cracker table, or is it pretty much a case of try something and see if it works?
Josh
Old Feb 19, 2006 | 01:48 PM
whatever your car wants
Old Feb 19, 2006 | 04:39 PM
RedWS6 00's Avatar
Below is my Throttle table in a 2000 M6, I have no problems, just wanted to upload this for comparison.
Attached Thumbnails weirdness in the Throttle Cracker; stalling fix.-throttle_table.jpg
Old Feb 19, 2006 | 05:35 PM
thge stock 2000 table sucked for me, rpms wouldnt come down from 1600 until i slowed down below a certain speed
Old Feb 22, 2006 | 08:46 PM
BAIN's Avatar
So what table did you use? How did you put a different table into your 2000 program? I have a 2000 A4 and I still cant get my rpms to come down from 1600 for a few seconds like you said when stopping.
Old Feb 22, 2006 | 09:07 PM
what tuning software do you have? 1600 rpm on a stock tune adds 3 g/sec in the 2000's and is a pita lol lowering that is what helps out. let me know what you have to tune with, should be the same in all of them, its the throttle cracker airflow. the one i posted is the one in my car
Old Feb 22, 2006 | 09:13 PM
BAIN's Avatar
I have HP Tuners. I put the values of your's in my tune and it helped some.
What should I do with the delay/decay areas? 0 them out?
Old Feb 22, 2006 | 09:16 PM
BAIN's Avatar
I'm switching back to MAF from a SD tune and am having problems with getting the idle straight and the whole cruise control/high rpm when stopping.
Old Feb 22, 2006 | 09:27 PM
email me your bin budchevy358@yahoo.com and ill compair it to mine to see where you might beablet to fix it. are you t-rex and full bolt ons only?
Old Feb 22, 2006 | 09:38 PM
BAIN's Avatar
Yep T-Rex only w/bolt-ons. I will send the one to you before I started messing with it. Do you need a log also?
Old Feb 22, 2006 | 09:44 PM
yeah send that too
Old Feb 22, 2006 | 10:01 PM
BAIN's Avatar
sent
Old Feb 23, 2006 | 06:01 PM
Josh's Avatar
Please post your results when you get it straightened out. My RPMs are hanging around 1200 before coming to a stop, so I'd like to see what needs to be changed to make it behave correctly.
Josh
Old Feb 23, 2006 | 11:34 PM
what year is your car? usually if its a throttle cracker issue, most hang at about 1600, if its around 1200 it can be idle airflow too high if you have adjusted on it
Old Feb 24, 2006 | 12:03 AM
Josh's Avatar
It's a 99. Earlier this week I redid the RAF and reset the TPS, so it's open 3 percent.
Josh
