LTrims parameter
Old Feb 6, 2003 | 10:17 PM
Gev's Avatar
Gev
Default LTrims parameter
Hi I just got AutoTap and don't really know what some of the parameters are and what they mean. I have an aftermarket MAF and i've heard right and left that it can be a problem so all i care about right now is checking my LTrims/tranny line pressure. Where is this parameter and what value do i want it to be at?
Old Feb 6, 2003 | 10:39 PM
NoGo's Avatar
Default Re: LTrims parameter
It is referred to as Long Term Fuel Trim B1 and Long Term Fuel Trim B2 on a-tap. While driving around, just glance over at the laptop and make sure that your Lterms are within +15% to -15% and you should be fine.
Once you get tuned, or want to start making changes with an MAFT, then you need to start adjusting them to be slightly below zero for best results. If your PCM is 'tuned' then they need to be slightly negative 95% percent of the time and very close to ~0% when you go WOT.
Good Luck,
Kevin
