42# Lucas injectors???
The part number I listed is a GM part number, they are used in the GM Grand AM Cup Corvettes, and also used in the SC 3800 V6 engines.
Not cheap, $450 for the set.
They are same design made by Bosch.
<strong> Yes I was able to tune these injectors in real nicely via LS1edit, no problems.
They are same design made by Bosch. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you have the offset table for these injectors? Is it needed or did you stay with the table for the C5?
Den
<strong> Do you have the offset table for these injectors? Is it needed or did you stay with the table for the C5? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">These Bosch GM injectors are exactly the same internal design as stock ones so there is no reason to change voltage offset, internal coil is the same so Yes I left offset alone.
