Will computer lean mixture on WOT after some time?
Is there a similar computer strategy to richen the mixture at wide open throttle after a few seconds at a leaner mixture?
Here is a link to an Excel file showing what I recorded on the drag strip on Sunday on a 100 shot with one run on motor.
When asked to update links, reply "no"....
http://members.***.net/joelynch5/wall209.xls
Any input on what may be happening I will appreciate.
Joe Lynch
I've tuned several EEC-IV computers with various software. I remember a blower car on the dyno a while back that would add fuel under some unknown condition. At the time the software he had hadn't defined some key tables for adjustment. My guess was it was tied into an air temp/coolant temp parameter that added fuel.
<small>[ February 12, 2003, 01:23 AM: Message edited by: Mike Morgan ]</small>
I bought a used timing adjustor and will put that on, pull the TwEECer, and see if the problem reoccurs or not. My bet is that it won't.
I can't imagine a strategy within the stock Ford or GM computers which would modify the ratio at WOT after seeing something else change. But I thought I would ask since at least one fellow thought that the LS1 computer had done it.
Thanks again,
Joe
