Forcing Closed Loop
Old Feb 20, 2006 | 11:59 PM
LoWeLL216's Avatar
Default Forcing Closed Loop
Is it dangerous to force closed-loop operation from a start-up situation?
After an injector swap I get freefiring on deceleration and on shifting from cold startups until the car enters closed-loop.
I logged my commanded AFR from startup and it goes from around 9:1 to stoich following a decay rate that lasts slightly over 2 minutes. As soon as the car enters closed-loop the freefiring stops.
I tried forcing closed-loop just to see if it had any effect and sure enough the car didn't freefire at all. Obviously this isn't the solution since I don't want to start my car commanding a 14.7:1 AFR with narrowbands that aren't warmed up yet, but it is strange that it works.
Also, what forces the car into closed-loop from open-loop? I know it's more than just your ECT. Thanks!
Old Feb 21, 2006 | 01:22 AM
P Mack's Avatar
You may just want to mess with your open loop F/A vs ect table.
Old Feb 21, 2006 | 01:45 AM
ringram's Avatar
Agreed, sort out your open loop VE and fueling instead.
You cant force closed loop when cold as O2 sensors wont work properly until hot.
Old Feb 21, 2006 | 04:43 AM
TAQuickness's Avatar
agreed agreed. the freefiring you refer to is the excess fuel lighting off in the exhuast pipes aka raz.
Old Feb 21, 2006 | 08:07 PM
LoWeLL216's Avatar
This may be a stupid question, but do you need a wideband to tune your OLFA table?
