PCM bench programming cable
Ed, Steve, and the other big-name tuners must have something they use for mailorder PCM's.
You can definitely make your own and it isn't that difficult - the hardest part is probably getting the proper connectors for the pcm (alternatively you could just manually insert the pins each time).
Chris
www.speartech.com/compreprog.html
It's a nice cable, but i built my own 6 months ago before i found these guys. Hope this helps.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
http://www.akmcables.com/jeremyharness.jpg
FYI, the LS1 connector can be purchased as GM part number 12167308 - that contains the metal shell, white inserts, and a pair of the blue, black, red, and clear connectors. To cover both the blue and the red connectors, you have to buy 2 of these kits.
Edit: You may wonder why all the switches. One is for power, one is for ignition, and the two in the middle allow the user to toggle between 97-98 PCMs and 99-02 PCMs (which puts power / ground on different pins).
-Andrew
<small>[ February 17, 2003, 07:10 AM: Message edited by: Camaroholic ]</small>
