Can I use LS1Edit without a dyno?
Old Feb 23, 2003 | 12:40 AM
LSs1Power's Avatar
Default Can I use LS1Edit without a dyno?
I will install F4 Cam 226/226 114 on a M6 with all the mods in the list + FLP's. Anyways i dont have a dyno close to me.... Can i tune the car with LS1 Edit without a Dyno? And if yes, can someone tell me the easiet way to do it. I will be needing Autotap right? Thanks
Old Feb 23, 2003 | 08:05 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Can I use LS1Edit without a dyno?
All you'll need is A-tap.Start simple with raising the idle and rpm limit then go from there.I use a MAFT to make changes to A/F,then you can transfer that to Edit.
