Engine Sensor Fuse blown
Old Feb 23, 2003 | 03:03 AM
Krazy98Z28's Avatar
Default Engine Sensor Fuse blown
Wondering how it blew and what exactly does it control??? I noticed it while i was pulling out my fuses to reset the PCM and I saw it was blown. My car still shows the SES light even after replacing it. I have a feeling that my O2 Extention being broken where it connects is screwing my car all up.I have electrical tape all around the connector because there is no clip to hold them together. Could this cause problems with the O2's. Car is getting sickning already. I never had issues with my last setup. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Feb 23, 2003 | 08:03 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Engine Sensor Fuse blown
It is not uncommon to get the engine light with the Cam you have without having it tuned for it.You need to A-tap it again to make sure the sensors are working.Did you check around were the piston came through the block to make sure no wires are cut?Were there any sensors in the intake that got damaged?
You could always go to my house and I'll put A-tap on again <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 24, 2003 | 12:55 AM
Krazy98Z28's Avatar
Don,
once I get that wire extention replaced i wanna A-Tap. I'll let you know when I am ready. Thanks.
Marco
